How to create helix around cylinder or cone
@Cdaum
Sketch a Circle > Add > Construction Plane > Perpendicular to Curve a Point [this is shown selected for clarity]:
Select the Light Blue Circular Shape > Pull up to the desired height [In this case 10mm]
Double Tap with your Finger on the Construction Pane [CP] [zoom in so that you can hit the target accurately, you can Scale the CP as required]
Sketch > Circle from Centre [used in this case but you can use any Closed Shape to Extrude or in contact with the Cylinder to form a Mark/Groove/whatever] ] in the desired position on the CP
Add > Construction Axis > Through a Cylinder or Cone:
Tools > Revolve > Select the Circle sketched on the CP [zoom in to the Circle or tap on the Navigation Cube top right to orient the Design into 3D if necessary to achieve the ‘highlight’] > Next > Select a Line or Edge for Axis > Hit the Added Axis
In the Dialogue Box top Left tap the ‘0’ under Height > Input in 10 or destination height needed then Hit the Green Checkmark area [the resulting Body has been coloured Red for clarity]:
If e.g., you need two revolutions change the Angle to 720º, and so on.
