Low poly exports from high radius items
here is a excerpt from a model ive made, its a sticker label that goes on a curved surface. i cant exactly remember how i modeled it but i think i just drew a side profile with the arc tool, then extruded up or something.
so, i am noticing that .obj exports are making high radius items really low poly. it makes sense, and even seeing this huge radius in shapr seems like its not proper, so im not surprised it doesnt export very clean. so, im wondering if there is a way to sort of.. get rid of this radius attribute or something, something that will help export this with the smooth curve it has in shapr. ive tried exporting to step and reimporting that step, and exporting as .obj again but i get a similar result alas slightly improved.
Are you using a paid or free version of Shapr? The free version renders exports in low poly. You need the paid version to get high poly exports.
if i had the free version then i wouldnt be able to export to obj man
What if you export as STL then import into Blender. Different result?
Or turn into quads and subdivide?
Turn it into quads then re-mesh by subdividing
Keep in mind Blender isn’t really a cad tool. Sure you can do cad like stuff.
exporting to .stl helped retain the curve yep! but it discarded the mesh seperation in my model and the colors too… so thats kind of a dealbreaker unfortunately.
i was interested in knowing why the huge radius items were becoming low polygon in the export, and if there was a solution to fix those faces to not read as an obnoxiously large radius in shapr itself. i basically need a shapr workaround here to have it export cleanly.
i am not very comfortable with modeling in blender, and i dont want to alter the topology if i can help it :confused:
Did you try to redraw the curve using spline instead of arc?
I played around a bit with the export settings.
As it turns out, the angle threshold has a lower limit of 0.01, I can’t make it go any lower. Since your object is nearly flat but not quite, that angle tolerance unfortunately translates to rather large polygons.
One workaround I can see is that you scale up your part along the z axis by a certain factor, export it, and then scale it down again along that axis in your target application. Certainly not elegant, but It would result in a denser mesh.
Know your tools and their limitations to determine best fit case for your design needs.
In Blender you wouldn’t necessarily make a label as a separate item. Much easier to project a UV mapped label image to a model surface. That’s where Blender shines. And you can map to low poly items and make them “look” high poly. Blender can also work with meshes that are more like paper than Cad programs can.
The more polygons in Blender objects the more overhead in your project.
Mixing Cad objects with Blender has it’s caveats.
If you create content, no one tool does it all.
clever.. the spline bypassed the massive radius value, but unfortunately export suffered the same result.
you are inside the stl export settings, so unfortunately this doesnt help as i am exporting as .obj - but good thinking!
this actually worked decently well, exactly as you described too. its at a cost of about 40,000 more tris.. but oh well. very clever!!!
i wonder what the proper fix for this is however.. maybe better export optimization supporting bigger radiuses? like you said, while this fixed the issue it came with a cost of extra topology where it isnt really needed.
thank you doctor!
Out of curiosity what is Blender’s role in this project?
blenders role in this project is uv mapping and pbr materials - no modeling is being done inside it. im creating assets for an app im developing :slight_smile:
That’s what I figured. Things are easy to flesh out in Shapr.
STL and OBJ export do the same thing, but in Shapr there are no custom resolution settings for obj exports. That’s why I showed the STL export screenshot.
Expectedly both produce the same issue with nearly flat objects. In fact I would be very surprised if they used different algorithms, the difference between an STL and an OBJ is really just metadata.
I just looked into the blender extensions.
There is a STEP file import extension for blender!
I think that could potentially produce better results. Export your part as a step file and then use the blender extension to import it. It’s possible blender has better options then to avoid the issue in the conversion to a polygon object.
yes! i am familiar with the STEP import extensions for blender, ive tried about 3-4 of them. they all have weird quirks, and ive even chatted with a few of the devs of each extension to fix bugs that were present. i ultimately landed on one from the blender extensions page, but it still gave an undesired topology count, and incorrect normal lighting so i opted for obj exports instead.
i could try making my own STEP blender extension but lets be honest, the elephant in the room is shapr’s exporting needs improvement. usdz exports are bugged, and i suppose it needs a little better support for high radius items like i’ve just discovered.
