I’ve been working with a product design today and when putting it through the visualiser it worked fine for a while and then started giving me some crazy output as shown in attached image. I figured some error was just playing up so I gave it a restart. Worked for a bit, then started up again, worse than before. Decided maybe my package had corrupted so deleted app and redownloaded from App Store. Same issue.
Changing environment just makes different versions of weird:
Reverting everything to default materials doesn’t resolve issue.
Issue is also not with file, this is happening across multiple files.
Product is fine in Modelling mode as shown in screenshot. Issue is with visualization.
Definitely a program issue that is shared as when I create a brand new file in a new folder and visualise without anything built I see remnants of previous craziness show up on the screen from the initial product.
MacOS Specs
Help would be greatly appreciated.
Seems to be set off when I select the materials further down the list or tried to change the colour and then rotate the product to view from a different angle it just started going crazy on me. Also interested to hear if anyone else is running into this issue.
Joseph
