Non-manifold detection
I’ve created a model that I was getting ready to 3D print.
I’m getting a warning :warning: in the slicer software (Lychee) that the STL is non-manifold, and I cannot find what might be causing the error in the original model created in Shapr3d.
I know that if you are in the process of modeling a feature in Shapr that is non-manifold, it will give you an error message. I don’t recall that happening though.
Is there any tips or tricks to find non-manifold geometry?
Thanks.
For starters, is the body you exported one solid body? Meaning, it not composed of more than one body that have yet to be UNIONED as one.
@TigerMike yes, I did verify that it is one body.
A couple days ago it wasn’t because I did not know it would be an issue, so I tried it as one complete union, still no luck.
Part in question.
A1F7BF15-3391-41B8-8DF9-E4B8B1B8D5BF_4_5005_c
You moved the body and there is nothing else that exists in that space? Try making it transparent and look for internal anomalies?
Try splitting objects/parts in Lychee and see if something reveals itself.
@Oregonerd I guess I can split the part into multiple pieces, import them individually into Lychee and see what body has the problem.
And yes, there are no other bodies.
A good tool for checking manifold issues is MeshMixer. It has an analysis mode where it will identify non-manifold and other issues.
@TheBum thanks, I’ll give that a shot.
@TheBum It totally worked great, thanks!
Turns out there was a surface non-manifold issue AND a hole issue, that I NEVER would have found.
One click and both were fixed. I imported them into the slicer and the errors are gone :+1: :+1: :+1:
@NathanD where in the model did you find the non-manifold issues?
@Istvan these were the errors pointed out in mesh mixer.
I then went back into the model in Shapr, searched, and found it.
This is what I found viewing “inside” the part.
Like I said, I would have never found it. :woozy_face:
How did you rectify the last one?
@Oregonerd mesh mixer has a repair function for the mesh body. One click fix.
I have not tried to fix the Shapr model.
