Option to auto separate objects and orientate to take least space with minimum gap
Some commercial 3D printing services have a cost that reduces if items are nested to take up less space overall. i.e. the less internal/empty space the better/cheaper. Think of a cube - if you instead stack the six sides a few mm apart it’ll take much less space.
An option where it separates all objects and rotates and translates them such that they are not touching and taking up as little space as possible. Be able tp specify the minimum gap between any edges/surfaces.
I have to do it manually, which is of course incredibly tedious. It needs to be an operation one can use just prior to exporting as an STL for sending to a commercial printing service.
It’s slowing me down!
What you’re asking for sounds more like slicer functionality — and slicers handle this kind of task easily, in just seconds.
I’d recommend preparing your project in a slicer before sending it to a printing service.
Well yeah that’s one workaround, I suppose, but it would be nice not to introduce another piece of software.
