Unable to find an efficient way to center objects with precision.
Often times “snap” is not accurate leaving the user to fiddle to get close but not dead on.
This project has a hook that is off by -0.06 and there is no way to get this centered.
The increments are only 1mm per and entering in a negative number like -0.06, when selecting move does nothing.
It’s frustrating to have to first add measurement points only to discover that when you move a selected object, the measurement numbers only update after you have released movement with the pencil. They do not update in real time as expected. Even more so when. You’re told that users can only add one embedded image.
