Preset function for selecting faces
Offset faces no longer function when I select faces
Is it possible to operate like the official version?
When I select a face, the default function is to offset the face
Beta version -
Old version
It’s just the defaults that changed, you can switch to the offset face anytime. We’ll tweak the defaults.
@RossiWu, just one more question to understand your background: do you use other CAD software (like Rhino, Solidworks, Fusion360 etc.) regularly? If you do, which one? Your feedback is important in either case, we’d just like to understand the preference of users with different backgrounds as we want to be able to serve all of them well.
I use nx10(UG10) to make 3D mold
Shapr3D is great software and so is your team
I hope surfaces will play a role in your future plans
it will help me a lot
Thanks this helped me a lot
Thanks for the info! In NX, which mode did you use more in the past 3 months, Synchronous or Ordered?
Ordered
most of time I need to switch SH3D&NX in complex surface
