Reduce Copy Paste Duplication
By now I hoped muscle memory would kick in and I would finally uncheck the Copy Button before doing the operation.
But I still make unintended copies. So I have a suggestion.
When you uncheck COPY could it undo the COPY and make it just a move? I hope that makes sense.
Option 2, can COPY be more of a toggle, one time and it deselects itself.
Hopefully you would expend on your settings panel so these can be an option to toggle off and on based on users preference.
Please expend your settings panel so these can be an option to toggle Off and On to Users Preference!
Did you have a fix on this e-ztag.org issue?
