If im not mistake, currently the only way to turn “Copy” on and off in the GIZMO is to manually click on the copy badge.
This is a pretty inconvenient workflow issue. It would greatly speed things up if I can bind “copy on/off” to a single key. this would not only greatly increase efficiency, but I believe it would also greatly cut down on the amount of times I inadvertently make a copy of something because I forgot to toggle off copy.
