Replace face shortcut
me having to click the ellipsis button to see extra tools every time i want to replace face
a quick shortcut assigned to this tool because i use it so frequently - maybe R if it isnt being used
its a workflow blocker and slows me down, yes.
Replace Face is one of my favorite tools and I use it frequently. I rarely go to the Tools list to select it first. I usually select the source face followed by the destination face, then I select Replace Face from the tools list as it is made visible. BTW, I’m on an iPad Pro.
I use R as the shortcut to do Replace Face on a Mac. I don’t think it was set this way though. I just went settings →Keboard Shortcuts (Customize Button) →Tools→Replace Face and set it to R.
You can do this on the iPad with a keyboard as well. I assume it’s possible under Windows too.
To make this faster I wish Shapr would make the last selected face the default face to snap to snap to instead of whatever it does now. I almost always have to select the faces, press R and then reselect the snap to face.
ah, didnt even try selecting both faces first. thanks!
i am so oblivious, i should have checked the settings first. i didnt know about custom shortcuts. this post can be disregarded.
