So, I looked aroud for the matter of resizing. I found a mention of the yellow thingy. However, the yellow thingy only sclaes the whole group. What I’d like to do is resize width or length, not rescale.
Thoughts?
Jose
Thoughts?
Jose
Hi Jose - currently we only have uniform scaling, meaning you can only resize your shapes through all dimensions.
We are currently working in a release, which allows you to Transform (move/rotate/scale) edges - one by one. Would that solution help?
If you give me a specific example for your problem, Im happy to find a workaround - if possible
Hi Daniel,
Indeed, that would help make it more intuitive.  I did find that if I wanted to elongate a side, I just had to tap on that side, then “pull/push” the side.  Though it took me a while to connect that the extrution technique can be used for re-sizing as well.
Thanks!
Jose
