SVG file exports for Shaper Origin
Hi All, a bit useless at starting new threads etc so hopefully this will work.
Into 2024 now and I use both shapr3d and shaper origin. I’ve tried using various export methods form shapr to my origin hub and found that only the svg files show up and work, HOWEVER!? Every time I go to the origin tool the drawing has re sized?
For instance, today I drew a simple drawing (sketch) for a pivot hinge, measured approx 70mm x 10mm. When I checked the imported drawing in origin, directly on the tool screen, just checked it against the grid lines, it had grown to 90mm?
Please help…. What am I doing wrong, what is it doing?
Thanks so much.
