SVG Import needed for imported designs
as the title says.. SVG import
DWG / DXF are very problematic, causing tons of extrusion issues, laggy or bogged down system and hours of wasted time trying to find where there are 2 or more points on top of each other or a tiny area where the vector path crosses itself…
These issues are not in the original vector graphic created in Illustrator, it is caused by the DWG / DXF formats.. My AI file has a minimal number of points to create the design, but when I bring it into Shaper3D as DWG, there are TONS more points this format has added.. so it can take HOURS to find all these issues in order to get it to EXTRUDE properly without failing…
Seconded. Im seeing this feature has been requested many times over the last 6 years. DXF and DWG just dont work at all.
