This bug has been here for the last 3-4 updates
I can’t drag with the mouse. Moving planes or faces always throws an error.
I notice the same problem , and what I do is to closed and open the program again to solve it :relieved:
Hey Coffee,
Thank you for reporting it! Can you provide exact repro steps please? Is it related to Isolation mode? By moving faces you mean using Face Offset tool or Transform tools? Which Shapr3D version do you use?
Hi… It effects everything.
I think it has something to do with rendering so much and trying to pick a object.
I think the code to draw the pick colors is hammering something about the actual mouse position.
I think It’s reading the mouse way off when there is too much data… either from rendering lag or mouse lag. It doesn’t effect smaller files. Everything is prefect as coded. I love it
I would check mouse polling when there is a lot to render.
Yes… This is a workaround for now. It will still stop dragging again after a while on my system.
This is Fixed!! THANK YOU THANK YOU THANK YOU!!!
Well… this is NOT fixed. Same issues on large files.
Dragging planes, faces or extruding is throwing “something when wrong”.
Guys… This is starting to make it unusable. Typing in works but mouse drags keep crapping out!
