With document units set to inches, the Thread tool still offers only metric sizes. Inch-threaded parts (1/4-20 camera mounts, 3/8-16 stand hardware, 5/8-11 baby pins) can’t be modeled to standard, so I end up modeling the thread in Fusion 360 or Rhino and importing a STEP, which loses the parametric link.
What I’d like
- A Standard selector in the Thread tool: ISO Metric, Unified Coarse (UNC), Unified Fine (UNF). UNEF and 8-UN would be nice to have.
- Default to UNC in imperial documents and ISO Metric in metric documents, switchable either way.
- Usual designations in the size list (#4-40, 1/4-20, 3/8-16…), pitch = 1 / TPI.
- Same options as metric: internal/external, length, modeled/cosmetic.
- Show the tap drill for internal threads, plus an optional clearance offset (e.g. 0.005–0.015 in) for 3D-printed parts.
- Thread callouts in 2D drawings in inch notation (e.g. 1/4-20 UNC-2B).
The thread form (ASME B1.1, 60° flank) is the same basic profile as ISO metric, so the existing geometry should carry over with inch dimensions.
Minimum sizes
| Size | Major dia (in) | UNC TPI | UNF TPI |
| #4 | 0.112 | 40 | 48 |
| #6 | 0.138 | 32 | 40 |
| #8 | 0.164 | 32 | 36 |
| #10 | 0.190 | 24 | 32 |
| 1/4 | 0.250 | 20 | 28 |
| 5/16 | 0.3125 | 18 | 24 |
| 3/8 | 0.375 | 16 | 24 |
| 7/16 | 0.4375 | 14 | 20 |
| 1/2 | 0.500 | 13 | 20 |
| 5/8 | 0.625 | 11 | 18 |
| 3/4 | 0.750 | 10 | 16 |
| 1 | 1.000 | 8 | 12 |
Impact: This blocks inch-based work for me. I’m a gaffer in film/TV; nearly all rigging, grip and lighting hardware is inch-threaded, as is most US woodworking and a lot of hobby printing. Right now this is the main thing sending me back to Fusion 360.
