Transform handles disappear unexpectedly
Hey Shapr3D folks, can you tell me why the transform handles disappear sometimes, and then end up jumping far from the object being transformed? I’ve seen this behavior appear consistently in many versions of Shapr. What’s going on here?
Is there a slight arch on the bottom? If so, then the Move-Rotate anchor can at time move to the origin of the arc.
Thank you for that explanation. That may be what is happening, although it makes no sense. Why would the handles jump to the origin point (completely out of the frame of view)? Who does that help? How is the user expected to move (or align) a body with an arc if the transform handles refuse to snap to a corner?
Well if you want to move a body to follow an arc… it needs to be at the origin of said arc. Makes sense to me
