TV wall in oak, from the Shapr3D model to the finished piece
I’m a cabinet maker. This TV wall went from a Shapr3D model to my workshop and then to the client’s living room: two tall oak panels, a low unit with eight doors, and the TV between them.
The slow part of a job like this used to be the cutting list. The panel saw needs a list of parts and a layout for every sheet. For this one I exported the units as STEP files and dropped them into a small tool I built for my own shop. It reads the panels with their sizes and thicknesses and lays them out on the sheets, with grain direction and edge banding.
I have since made that tool available to other workshops. It is called Cutter: Cutter: cutting plans from Blum's Cabinet Configurator
How do others here get from a Shapr3D model to a cutting list?
This looks really useful, I actually wish I had something like this for Shapr about four years ago when I was working at a furniture factory. Back then, I had to export everything to Mastercam just to generate nesting layouts, and the whole process was such a hassle. I eventually switched to SketchUp, where I found an add-on that did the same right from the program. This is exactly the kind of innovation that small workshops, hobbyists, and small businesses need to make prototyping and production more accessible. I’m curious, does nesting function with Cutter works with irregularly shaped panels as well, or is it limited to rectangular pieces? Also, can it recognize the grain direction from the materials and textures assigned in Shapr3D, or does that need to be configured separately?
Thanks, Angel. Exporting to another program just to get the layouts is exactly the hassle I wanted to get rid of.
Shapes: rectangular only for now. Cutter makes panel-saw layouts, so straight cuts, with saw kerf and a cut order. If a panel in the model has a cut-out or an angled edge, it plans the rectangle around it and marks the part “not a plain rectangle – cut L × W, then shape”. Holes for hinges and shelf pins are ignored. So it is not free-shape nesting for a CNC router yet. I’m working on nesting for CNC too, but it isn’t ready.
Grain: it doesn’t read materials or textures from Shapr3D. It takes the geometry from the STEP file, and you set the grain in Cutter. Each board in the materials list has grain on or off, and on boards with grain every part starts with the grain along its length. One click turns it across the width, or sets it free so the part may rotate. In practice I change only a few parts, like drawer fronts with horizontal grain.
Which add-on did you use in SketchUp?
