Hello Shap3r, small quality of life feature requests here.
#1
As you know “return_or_enter” on MacOS is the universal rename hotkey. On the Project/Spaces screen within the app, this works to rename files or projects. But when in a drawing with a body or sketch selected on the left , this behavior is not replicated. This leads me to my next request as it forces me to rename is other unreliable ways.
#2
Similar to #1 above, selecting a bunch of drawings and right clicking them to add them all to a new folder mirrors the MacOS experience where it moves them all to the folder and immediately lets you edit the title of that folder without extra clicks or having to use the “return_or_enter” key.
Screenshots of this example:
Renaming
However, when working in a drawing, this behavior is not replicated. It is often that I highlight a few items, right click to add them to a folder, and then right click to click rename, and nothing happens. This is usually because there is a slight lag to the organization process, and the right click is happening before the animation of the items finishes, and the click doesn’t register. Another issue with this is because files are physically moving on the screen, it was choose to rename the first item in the folder instead of renaming the folder.
View or download a video showing this issue:
4.10.25_RenamingIssue.mov
Not a show stopper for me by any means, but a constant and repeating hiccup where I’m breaking a flow or having to do things over again but slower to give Shap3r time to catch up. Double clicking a title to rename is also something that is accepted in the projects view, but doesn’t work for items in the left side bar.
Thank you.
