Part 1
Es grüßt Sie aus Bottrop
Peter Basista
export 7.shapr (913 KB)
export 6.shapr (1.39 MB)
Dear Istvan,
I make completed documentation of error.
Export1= Holder-solid ( base+Holder)
Export2=Kabel-solid
Export3= Holder+Kabel unite
Export4=Holder+Kabel+rounded corners
Export5=Holder+Kabel+block to substract
Export6=Export5
Export7= error substract
Please find picture of bug…
It is very frustrated job.
I try to make all fine, check every step , unite the parts, make it fine…
Last step I loose all my work.
Hope this mail is not to big for your account.
To be sure I send files separate again.
I want to help you, to find the nasty
Peter Basista
export 5.shapr (913 KB)
export 4.shapr (1.38 MB)
export 3.shapr (180 KB)
export 2.shapr (208 KB)
export.shapr (81 KB)
Part3
Peter Basista
Thanks, let me take a look. You can manage your subscriptions in iTunes. This issue will be fixed in the next release.
I have successfully reproduced the issue, now I am looking into it.
This is NOT the solution, but if you cut the shape from the other side, it will work fine.
And since it is symmetrical, in this case it should work, but we will have to fix this bug indeed.
I have found the issue and fixed it, it will be included in the next release. Please find the fixed file attached, and we are sorry for the inconvenience. fixed.shapr (1.3 MB)
Btw. if you reply by mail to forum messages it will be posted to the forum automatically.
Hi István,Thank you for your help.
What do you mean: cut form other side?
I haven’t open your fixed.shapr file now.
Must go to the pc to Handel it.
The next version is comming ? At what date?
Regards to you and the team…
Peter
By the other side I mean like if you mirrored the box to the symmetry plane of the other shape.
Yes, Shapr3D 2.0 is coming very soon (few weeks, we are working on it like crazy)
