Visualization texture by user
The main materials I use for the object I design are marbles. Shapr3D is offering for visualization are white Carrara marble and black marble with white veins; this is good, but very limiting given the vastity of marbles available. If the user had the possibility to load at least a texture of its choice in the system better if more at the same time, with the possibility to reload others for a different object it will be really great. That of course following the rules Shapr3D will accept.
Brief description of the outcomes that you
This feature will permit me to create realistic visualization for the benefit of my customer to decide and then buy. The need was present since the beginning but now with the availability of regenerative visualization it is crucial to get the best from this last technology.
What don’t you achieve without this feature?
I make a two step approach using a sw that permit to select the texture on the 3D object and create renderings.
So the absence of this feature it is not a blocker, but its absence costs time and money. That I could save with ths feature.
This feature request addresses the limitation of current marble visualization options in Shapr3D, which only offers white Carrara and black marble. The core problem is the inability to create realistic visualizations for customers due to the lack of customizable marble textures. While this absence isn’t a workflow blocker, it necessitates a time-consuming and costly two-step approach using external software for texture selection and rendering. Implementing the ability to upload user-chosen textures would allow for immediate, high-fidelity visualization within Shapr3D, especially benefiting the use of regenerative visualization technology, thereby saving both time and money.
