Sure that would be helpful.
It is unfortunate that this forum software seems to have a bug or something in that it does not upload a group of selected screenshots in the order they were taken. Very frustrating…
Hey
My English is really not good to explained every thing but I try
1st this the main draw and lock every point in it
2nd u need to mirror to get this
Then with transform - move and select the center
With select all lines and copy option move around 120
And same lines with around 240
And make line for ever mid Line to tuch mid point like this
And lock every point so it not move when you extrude
Then make line between the line to get this
Use trim to clean unwanted lines
And extrude
I hope I explained in good way … sorry for my bad English again
Thank you for your explanation. Your English is fine. Your use of the Extrude tool with draft angle is somewhat innovative. I had only considered its use for more simple figures. Need to study further…
Absolutely amazing! Never worked with 3D CAD before, but after watching the Beginners Course on YouTube, I dove right in with no problems! I just wanted to get a 3D feel for a camper I’m thinking of building, and three hours later, I have a full concept built! Still learning of course, but amazing what you can do! The possibilities are limitless!
Looks real nice
We do Modeling Mondays monthly at Shapr. Last time I’ve tried to recreate a robotic arm I’ve just found while browsing.
… and I’ve rendered it on desktop:
Nice! What did you use to render it?
Thanks, I’ve used Fusion360
Almost done… !
That Knight is… wow.
Thank’s!
Just installed Shapr3D to see if the base curve of the lens and the lens groove was difficult to do. With Solidworks it is faster but to be able to do this on an Ipad is great. Missing textures and OBJ import for the 3D head scan. The design is going out for a full color nylon print and will put in hinges and lenses. Will share the result then. Very interested to make a template that can be used by eye care practitioners to sketch a frame. Export it as OBJ to our cloud based VTO system so they can make a 3D head scan with the Ipad Pro and show it on the face. Our configurator can then replace materials so you can build and size your frame and print it with us. I added an extra image of a full color print that was generated with our cloud based (mobile) system.
Very impressive work Marc! Thanks for sharing…
Tom
Excellent work by all!
