Improvements to parametric modeling
I upgraded. I do not see a change in the performance.
I guess I don’t understand, but why does it fall upon the user to improve the performance by merging history? It seems to me the software should handle processes that it creates. It should especially resolve those that are creating performance issue. If it is up to the user to solve the performance degradation, the problem within the software is not remedied.
May you consider a design idea? Create a key field that will link each sketch with each body and every subsequent sketch with that modifies same body. Each sketch will get a key which links it to the body made from it. Each subsequent sketch that is not the first sketch but modifies the body ties to that first sketch via the key but with a sequence number added. Sketch 88, Body 88 is an example of the first sketch and the body. Examples of subsequent sketches that alter the body but are not part of the first sketch would look like this Sketch 88-1, 88-2, etc. This shows the association of the first sketch and body. They are number 88. Sketches that modify the body are numbered by the second number. They are 88-1,88-2. The program will identify that the subsequent sketches modified the body.
I wonder too if somehow something like this suggestion could help manage the history? Could it essentially become the merge that you are asking us to do? Instead, it becomes an automatic merge and a way for the user to keep track of which sketch goes with which body and all of any number of subsequent sketches altering the body. The user could browse or search through the history for the key field. I wonder if this could solve a few problems?
You can still allow the user to name the sketch and body, and subsequent sketches. The key fields should remain a part of the name. I know on the Mac that the name field is sizable so that the whole name is viewable. On the iPad the name field is limited making a long name difficult to discern since most of it is hidden. The other problems it would solve makes it worth considering.
Note, I have done my part to address the speed issue, because I have no time at the moment to wait for speed improvements. I have upgraded to a Mac Studio, after finding poor results from the iPad Pro with 8 GB and 16 GB RAM and a Mac mini M2 Pro. My drawing is an architectural drawing which is well within Shapr3D’s capability and intent. I am holding onto my iPad Pro M1 for viewing. My Mac Studio still shows some lag, but snappy lag. It lags but catches up quickly. I will use it for the bulk of my drawing process.
Shapr3D has proven very useful. As of late, it has become a problem to solve. I sincerely hope it get back on track.
Funny, I must’ve misunderstood this feature - I think what i was hoping it was was a means of projecting forward into the future. A kind of time traveling projection. Say if you’re in sketch 2 but there’s a line or circle in sketch 12 that you want to project into the earlier sketch. When you hit project the 12 sketch disappears entirely which is so annoying. I’m wondering that surely there must be a way to get round this, or is it a limitation of parametric modelling. Even if you had to create a separate projection tool I’d find cool.
I know the work-around is to create a new sketch that’ll sit above the sketch and therefore be able to access the projection tool capability.
Ah this function is working for me now - I can now project off any line in any drawing I make which is awesome for trying to align to items in sketches you made in the future. Made a huge difference to my workflow. Last time I used Fusion360 I couldn’t do this so that’s great. One less thing to drive me mad :slight_smile: Thanks
There have been some good updates lately. Keep them coming.
Im sorry but, if you close the history everything will “look” as before but we all know there’s still big performance degradation that makes difficult to use on iPad too laggy
I have the same feeling - that engineering rather than free design has encumbered the beautiful ux, especially on Ipad. While I hugely appreciate the improvements and much of the magic, I beg for a history toggle. Stopping frequently to click history, click merge, then click back to my work is truly crazy making.
